Hello everyone!
Recently I've purchased an 1998 328i sedan with the zf5hp19 transmission that goes into limp mode intermitently... It is totally random. In six months it did around 2 or 3 times. Simply turning off the car and restarting makes the limp mode go away.
I went to find what was happening, on INPA it says that it was torque converter slipage, but digging a little further I believe that this is due to the temperature sensor in the harness not working.
I let my car parked for around 1 week without running and when looking on INPA the gearbox temp it showed around 240°F (~110°C) which makes no sense.
Measured the pins on the ECU connector and found that the sensor is "open" (pins 21-22) giving me infinite resistance, thus, leading to this max temperature reading.
Already tried reconnecting the connectors to no avail. Them only two options left now which I'd like to know if someone as a clue to help me see what would be best.
1 - Leave as it is
2 - Change the harness
Has someone seem this problem before? For what I saw on videos I would need to drop the valve body due to one solenoid which stays behind it. I'm not confortable to take transmission out of the car but I would try only the valve body, question is... is it possible to drop the valve body and remove/reinstall a new harness without taking the transmission out?
What would be the consequences of leaving this as it is besides the intermitent limp mode? could this cause damage to the transmission?
Thanks a lot in advance!
Gabriel
1 - Leave as it is
Gabriel
