Is it really necessary to remove the DISA valve, Throttle Body, ICV, etc stuff under the intake manifold just to remove the manifold? Seems to me just removing the stuff on the top of the manifold such as the fuel rail etc to access the manifold bolts and then remove the lower manifold bolt that the manifold should be easily removed. From there the coolant lines could be removed and CCV replaced if necessary.
