PROBLEM SOLVED. READ THROUGH THREAD I POSTED MY SOLUTION AND FINDINGS
I have a 2003 330ci that I recently purchased and only the instrument cluster lights are not turning on. The rest of the dash/message center/radio etc. work however.
I thought it was the kbus but if you turn the dimmer on the lcm, the radio and other dash lights dim along with the instrument cluster message center that shows mileage. Also the turn signals and high beam/foglights DO appear on the cluster, and by looking at an IKE pinout diagram, there is only one kbus pin in the IKE, therefore it should be working(?). I also messaged scott at bmwgm5 and he doesnt believe it is the kbus either.
I have tried swapping the lcm with a friends 325ci along with the cluster. The 325ci cluster will not light up in my car with a new lcm and my current lcm. I swapped my 330ci cluster onto his 325ci and it lights up. So I believe it must be a wiring issue somewhere. I tried doing a kbus reset last night and no luck.
I also checked fuses 10, 34 and 43 and they seem to be fine. On my friends working 325ci? i put the cluster lights on and pulled fuse 10, 43 and 34 and the lights did not turn off. therefore im assuming they are irrelevant to the lighting operation.
Any help appreciated.
