1 - 9 of 9 Posts
Is there an easy way to install a cigarette outlet under the drivers seat (or nearby) that will turn off when the engine turns off ?? Thanks
Banned
well there is an adapter bmw sells that takes the power of the rechargable flashlight in your glovebox to a cigarette lighter. let me know if you want the part number
Discussion Starter · #3 ·
I know about that part,however, it stays hot when the car is off. I need it to shut off with the car. THanks
Banned
what do you mean? well i dont have the actually ciig lighter piece in it, just the open slot in case i need to put my phone charger in
Discussion Starter · #7 ·
do u mean the stock cig outlet near the stickshift or are u talking about the one u can put in ur glovebox in the flashlite port ? I just tested the stock one and it does not turn off when u lock the car.
pardi said:
It will go off as soon as you lock the car.
Discussion Starter · #8 ·
Well, I hooked up with one of our fellow board members, CynicalWry, and he installed a new cig outlet for me under the coin tray in the center console, all hidden and out of sight, very nice job !!! Many thanks !!!
Well I think it depends on what you need the power for. If you just need power and do not need the cig lighter piece, just run a relay and connect the trigger of the relay to a hot wire that is only on when the car is on, like the do for the dde's. Hope that helps...
1 - 9 of 9 Posts
