WOW!!!
I just had to report back about this mod. This is fan-****ing-tastic. $2 in parts and such a massive improvement in driveability. If you haven't done this mod yet, you're missing out.
Parts Used:
1 - M10 40mm 1.5pitch Bolt
2 - M10 Nuts
1 - Big Flat Washer
1 - M10 Locking Washer
1 - Rubber Leg Cap
I put the two nuts on the bolt first, followed by the locking washer, then the flat washer. I screwed the bolt into the floor in place of the old clutch stop. Adjusted it out about a turn shy of interfering with the start mechanism. Tightened down one nut to clamp the washers in place, the second nut simply helped to hold the rubber cap in place.
Total time: 10mins.
This tuesday my CDV is coming out. Can't wait!!!
cya, Stew.
Parts Used:
2 - M10 Nuts
1 - Big Flat Washer
1 - Rubber Leg Cap
Total time: 10mins.
cya, Stew.
