1 - 1 of 1 Posts
For the time being I decided to hang on to the Dynavin and remain hopeful that the quirks will be addressed soon. Anyway it took me about 5 hours as I took my sweet time to avoid having to do it over or risking any damage.
Anyway I wanted to share with you guys another location to tap into a trigger wire that with plug into the green Reverse wire on the Dynavin. Sorry I didn't think to take a picture, but it's fairly simple. Once you drop the glovebox, look in the footwell where the bundle of wires are coming from underneath the carpet. Search around in that bundle and you will find the "Blue/Yellow" wire. There isn't a lot of slack in this area, but if you use a wire tap there will be plenty of room. This saves a lot of time not having to run a wire from the reverse light in the trunk or fiddling around with the junction box above the glovebox.
If audio still played while the reverse cam is on that would the the icing on the awesome cake! I highly recommend this MOD
1 - 1 of 1 Posts
