1 - 4 of 4 Posts
2003 E46 325i Sedan
Hello, I just noticed that there is a leak while washing my car with high pressure water. The leak only occured on the rear left side.
Not sure if it's the inner or outer door seals that's causing the leak. Or is it recommended to change both? Thank you.
Car Vehicle Window Car seat cover Motor vehicle
Hood Motor vehicle Automotive design Bumper Automotive tire
Car Automotive side-view mirror Motor vehicle Automotive lighting Hood
All joking aside, why look for trouble with high pressure water? BMWs are notorious for water ingress.
If it doesn't leak through a normal car wash or rain..... leave it alone.
2003 BMW M3 SMG Convertible; 2000 BMW 328CI 5MT; 1997 BMW 328I 5MT Swap; 1996 BMW 328IS 5MT Swap
you can pry (pull) a bit on that black weather-strip piece, its rubber and will only crumble if its old and needs replacing anyway.. if its really bugging you that is.. I personally just avoid spraying too much between the doors and the rear windows
1 - 4 of 4 Posts
