481 - 500 of 798 Posts
.......Also noticed that Primo 1.2 does not like me driving on the hwy. I checked my setting; HIGHWAY is checked (btw MOTORWAY in old Primo).
It kept bugging me to exit the highway every time it finds an exit. The old Primo does not do this to me.
Primo 1.2 has a few different settings, I'd go through all of them
Was TTS Pro supposed to be grayed out?
You need the TTS PRO voices to access the greyed out settings......http://www.mobilepassion.org/viewtopic.php?f=82&t=6539
I have the Pro Voices working... very nice!
And yes, here in the US "bear left" means turn left... unless you are here in the Rocky Mountains and then it actually could be referring to the large furry critter.:rofl:
OK, the previous link for Primo 1.2 got deleted by the hosting site
I've re-uploaded it with the file name Zokrad.zip :D
Hopefully it'll last longer this time.
This is the new Primo 1.2 with native 800x480 resolution
Includes the North America, 3d buildings, dem, phoneme, poi, speedcam files etc. along with working TTS voices so it's all ready for you to use.
New screenshots I took today, ooooh look at that pretty sunset.....
Download and unzip the Zokrad.zip file and copy the iGO Primo folder onto your SD card.........
http://www.filefactory.com/file/ca441a5/n/Zokrad.zip
You only need to add the USA map files.
The map files from Primo 1.1 will still work, so you can copy the map files from your previous Primo 1.1 to the content/map folder (or download link below for maps)
http://www.igo-maps.info/
Note:
- This info was gathered from a couple of sites, http://www.mobilepassion.org/viewfor...f895676799ea15 and http://fixmygps.net/forum/forumdisplay.php?fid=16 so I've just put it all togther for you and made it available for download.
- Custom skins, mapchangers and hacks etc. made for Primo 1.1 will not work with the new Primo 1.2.
- I recommend you not use any sys.txt file from any previous version of Primo, especially if you have custom entries related to any mods, custom skins or hacks as it most likely will not work with Primo 1.2.
- Only use the sys.txt included in this download and do not modify it unless you know exactly what you're doing and are sure it will work with Primo 1.2.
- The included TTS voice files had to be slightly modified to work with Primo 1.2, so if you add any other unmodified previous TTS voices they may not work.
- This will of course work for any country, you just need to copy the files from your particular region to the corresponding folders in the content folder.
That's enough disclaimers from me, enjoy.
Darkoz, thank you very much for the great upload. Unfortunately I can't download it: everytime it stops sometime around halfway and even with a program like jdownloader to restart where it stopped, it doesn't work...
Could you please post it on another fileserver ?
Thank you
