421 - 440 of 798 Posts
I've been using Primo 1.2 all week and it has been great. The US voices work now and the screen sharpness is excellent.
Thanks so much Darkoz! I hope others will be able to get this upgrade soon.
Steve
New download link for Primo 1.2
**Updated download link**
I've re-uploaded Primo 1.2 with the file name Engage.zip, get it while it's hot.
This is the new Primo 1.2 with native 800x480 resolution
Includes the North America 3d buildings, dem, phoneme, poi, speedcam files etc.
Also includes TTS PRO voices (announces street names etc.).......AUS Karen - UK Serena - US Jill - US Samantha
Download links -
Download and unzip the Engage.zip file and copy the iGO Primo folder onto your SD card.........
Fileserve download......http://www.fileserve.com/file/x98tPjN/Engage.zip
Torrent download (thanks to forum member loginfailed).......http://thepiratebay.org/torrent/6292481/Zokrad.zip
You only need to add the USA map files.
The map files from Primo 1.1 will still work or download link below for maps
Copy the map files to the iGO Primo/content/map folder
Maps download.......http://www.igo-maps.info/nac.php
Note:
- This info was gathered from a couple of sites, http://www.mobilepassion.org/viewfor...f895676799ea15 and http://fixmygps.net/forum/forumdisplay.php?fid=16 so I've just put it all togther for you and made it available for download.
- Custom skins, mapchangers and hacks etc. made for Primo 1.1 will not work with the new Primo 1.2.
- I recommend you not use any sys.txt file from any previous version of Primo, especially if you have custom entries related to any mods, custom skins or hacks as it most likely will not work with Primo 1.2.
- Only use the sys.txt included in this download and do not modify it unless you know exactly what you're doing and are sure it will work with Primo 1.2.
- The included TTS voice files had to be slightly modified to work with Primo 1.2, so if you add any other unmodified previous TTS voices they may not work.
- This will of course work for any country, you just need to copy the files from your particular region to the corresponding folders in the content folder.
That's enough disclaimers from me, enjoy.
Downloaded! I'm running into an issue though. I've ran into the same issue with Primo 1.1 and reloading it back into the card/usb drive normally corrects the problem
In the data fields on the non-route mode, It'll only display one field and it's usually the one thats highlighed in the menu that allows you to select what you want displayed (clock, altitude, compass ect ect). I've tried reloading v1.2 on the drive again but it won't display more than one data field at a time. Can you assist with the issue?
Also awaiting your updates on sys.txt The TTS again is drowned out by music from any source :)
iGO Primo 1.2 real time traffic?
From an internet blurb on iGO Primo 1.2's feature set:
"Connected services: real-time information
Routing and guidance can be optimized through live services on a navigation device via mobile network connections or embedded SIM cards. Google***8217;s local search function integrated in iGO primo® 1.2 looks up POIs online, based on the given location. Online Traffic delivers real-time traffic information, calculating the route by avoiding crowded road segments. Speed camera data is available online from classic data providers as well as from peer Alert Point Community members that report mobile cameras as they spot them on their way."
Has anyone tried this and gotten it to work on an internet-connected Dynavin? Very cool.
Routing and guidance can be optimized through live services on a navigation device via mobile network connections or embedded SIM cards. Google's local search function integrated in iGO primo® 1.2 looks up POIs online, based on the given location. Online Traffic delivers real-time traffic information, calculating the route by avoiding crowded road segments. Speed camera data is available online from classic data providers as well as from peer Alert Point Community members that report mobile cameras as they spot them on their way."
You need the ability to connect internet to the device.
I was able to get "Google Local Search" to work using the wifi hack...
.......... In the data fields on the non-route mode, It'll only display one field and it's usually the one thats highlighed in the menu that allows you to select what you want displayed (clock, altitude, compass ect ect). I've tried reloading v1.2 on the drive again but it won't display more than one data field at a time. Can you assist with the issue?
Just to confirm, when you're in the map screen where the data fileld is shown on the bottom right of the screen, if you tap that it will expand into 3 different fields, is that what you mean?
For louder nav voice, copy and paste this into your sys.txt file......
[dynamiccompressor]
compressor=1
a0=56806
thrs=24703
ratio=8 ;higher number = louder nav voice
gain=10 ;higher number = louder nav voice
[dynamiccompressor]
compressor=1
a0=56806
thrs=24703
Thanks, I've been so used to the diMKa skin that I forgot about the tap function from the basic skin. I didn't want to mess with the sys.txt yet until I got your ok on the dynamiccompressor script. I ended up just discovering that the "LOUD" feature actually quiets down the music per volume # while making the sound more full with the bass at "0" and treble at "5" and all the while making the TTS louder per volume # without having to add any extra sys.txt scripts
Glad it's sorted, most times it's just something simple.
I actually don't use that sound entry in the sys.txt as I find that although it does make the voice volume a bit louder it also makes it a bit more muffled, at least to my ears anyway.
And since I don't have an external Amp or Subwoofer I've always had the Loud feature turned ON in the Dynavin settings, without it everything sounds too tinny so my next project will be installing a 4 channel Amp to get more out of my speakers.
Let me know if you or anyone else gets the real time traffic part working; that would surely get me to buy the wifi hack.
In Settings there is a box to check for Online Traffic. I don't live in a very populated area, but will give it a go when I get to Denver next time. Concerning the wifi hack, the biggest drawback is that right now you need to manually select the ssid with every start up... It is being worked on but for now that's the way it is, so be advised before you jump.
Once "Online Traffic" is enabled you will see the icon on the right below quick menu. I am now running into an issue with an out of memory error when I run with wifi patch... stay tuned. Working on it...
Darkos would my selected Scheme's save if I create a save folder /igo1.2/saved ? It always defaults to default night/day after I shut off the unit.
NEVERMIND just looked back in the last page
Sinboo,
Please keep us posted. If realtime traffic works, I'll definitely spring for the wifi patch finally.
Thanks.
John
