401 - 420 of 798 Posts
Thanks a million Darkoz for the new upload. I have been looking everywhere and could not find it! Everything went smoothly. I do have a question about the media player. I assume that will read off of the micro sd and the usb, correct? Thanks again.
Your're welcome ngacleetus
I assume you mean the media player in the nav side, yes it can play music and movies off the SD card and the NAV-USB
New Primo 1.2 U.S Download
This is the new Primo 1.2 with native 800x480 resolution
Includes the North America, 3d buildings, dem, phoneme, poi, speedcam files etc. along with working TTS voices so it's all ready for you to use.
Just unzip the Darkoz_1.2.zip file and copy the iGO Primo folder onto your SD card.
http://www.filefactory.com/file/cafe28a/n/Darkoz_1.2.zip
You only need to add the USA map files.
The map files from Primo 1.1 will still work, so you can copy the map files from your previous Primo 1.1 to the content/map folder (or download link below if you haven't already got the US maps)
http://www.filefactory.com/file/b463gbg/n/Darkoz-US-maps.zip
Note:
- This info was gathered from a couple of sites, http://www.mobilepassion.org/viewforum.php?f=15&sid=c64f2cf234be90ea6ff895676799ea15 and http://fixmygps.net/forum/forumdisplay.php?fid=16 so I've just put it all togther for you and made it available for download.
- Custom skins, mapchangers and hacks etc. made for Primo 1.1 will not work with the new Primo 1.2.
- I recommend you not use any sys.txt file from any previous version of Primo, especially if you have custom entries related to any mods, custom skins or hacks as it most likely will not work with Primo 1.2.
- Only use the sys.txt included in this download and do not modify it unless you know exactly what you're doing and are sure it will work with Primo 1.2.
- The included TTS voice files had to be slightly modified to work with Primo 1.2, so if you add any other unmodified previous TTS voices they may not work.
- This will of course work for any country, you just need to copy the files from your particular region to the corresponding folders in the content folder.
That's enough disclaimers from me, enjoy.
Darkoz,
I just want to say thank you again for everything you do to help the rest of us Dynavin owners. Your work is very much appreciated!
I'll download these files and give 1.2 a try when I get home from work.
Thanks again!! :thumbup:
John
Darkoz,
I downloaded the new stuff and guess what...works like a charm!
Even Samantha!
One question...would there be a reason that you know of that canada maps won't work? Im not going there anytime soon.
Anyone having a problem with Primo 1.2 not locking in your map color setting... after every startup it goes back to default map colors. I really like Jove night colors but 1.2 will not hold on to this setting.
Just installed it last night and works great, still not smooth, but I can live with it.
Besides I end up using my android for navigation since it includes traffic (and traffic re-routing). But it's nice to see some updates to iGo.
Thanks Darkoz, you make things so easy for everyone.
I've tested it and it seems to work fine here
When you go in to the Map Settings and choose your day/night colour there is another option called Colour which has three options, Auto-Day-Night
If it's on Auto it will automatically switch from day to night and vise versa at sunrise or sunset or you can manually choose a day or night colour regardless of the time of day, so check to see what yours is set at.
^^ Actually scrap that, I just tried it again and your'e right DANe46 no matter which other map colour you choose it keeps reverting back to the default colours on startup.
It's definitely some sort of bug, I'll have to look into this a bit more and see if I can find out what's going on.
DANe46 - If you want to use the Jove night map colours, I've managed a work around for the map colours reverting back to the default colours when you start up the nav.
First of all make a backup copy of your whole Primo folder for safe keeping if you haven't done so already.
Use Winrar and open the data.zip file (just double click on it, do not unzip it) in the main Primo folder.
Then go to ui_igo9 \ scheme \ night \ color.ini
Now open the color.ini file with notepad and delete everything and then copy & paste the text shown below, then save the changes.
A popup box will appear asking if you want to update the data.zip file, click Yes
This will replace the default night map color profile with the Jove color profile, in other words now when you go into Map Settings the Jove-night map colours will be the default night colour scheme.
Let us know how you go, I did this to mine and it worked no problems.
Copy & paste everything below this line (except for my sig which is just too much woman for any paste job)
[INFO]
name="COLORSCHEME~Default Night Colours"
night=1
default=2
preview=""
[color]
0="ground", 0,0,0, 1
a="0_int", 150,90,60
A="0_ext", 150,90,60
d="0_int", 150,90,60
D="0_ext", 150,90,60
c="1_int", 120,90,60
C="1_ext", 120,90,60
e="4_int", 120,90,60
E="4_ext", 120,90,60
g="5_int", 120,90,60
G="5_ext", 120,90,60
h="6_int", 96,72,48
H="6_ext", 96,72,48
i="8_int", 77,58,38
I="8_ext", 77,58,38
k="9_int", 96,96,96
K="9_ext", 96,96,96
l="10_int", 77,77,77
L="10_ext", 77,77,77
u="12_int", 61,61,61
U="12_ext", 61,61,61
r="freeway_int", 120,90,60
R="freeway_ext", 120,90,60
s="poor_int", 61,61,32
S="poor_ext", 61,61,32
x="unpaved_int", 61,32,32
X="unpaved_ext", 61,32,32
z="ped_int", 56,56,72
Z="ped_ext", 56,56,72
b="ferries_int", 60,20,80
B="ferries_ext", 60,20,80
f="ferries_int", 60,20,80
F="ferries_ext", 60,20,80
j="ferries_int", 60,20,80
J="ferries_ext", 60,20,80
v="ferries_int", 60,20,80
V="ferries_ext", 60,20,80
q="train_ferry", 15,70,70
Q="train_ferry_ext", 15,70,70
1="orszaghatar szine", 200,0,0
2="megyehatarok szine", 120,0,0
3="kulterulethatarok szine", 100,0,0
4="nagyvaros kerulethatarok szine", 100,0,0
5="viz szine", 0,0,220
international_border=-1, 200,200,100
region_border=-1, 100,100,50
political_border=-1, 100,0,0
space=0, 0,0,0
stars=0, 200,200,200
guidancestrip="0", 255,183,8
guidancestrip_ext="0", 189,69,0
hazecolor=0, 0,0,0
zoomcolor1=0, 20,80,80
zoomcolor2=0, 30,120,120
zoomcolorfont=0, 150,150,150
zoomcolorglow=0, 0,0,0
loading_background=0,0,0
loading_text=0,128,128
3d_sky=0, 30,30,30
3d_grass=0, 0,99,0
3d_building_color=0, 128,128,128
3d_building_roof=0, 96,96,96
3d_faded_building_body=0, 128,128,128
3d_tunnel_master_color=0, 252,0,252
3d_building_outline_color=0, 0,0,0
3d_faded_building_wireframe=0, 192,192,192
guidancestripalt="", 255,183,8
guidancestripalt_ext="", 189,69,0
globe_atmosphere=0,0,70,114
globe_space=0,0,0
Partition_area=9, 0,0,1, 0
built_up=8, 25,25,25, 0
built_up_border=1, 60,60,60, 0
sweet_water=6, 20,30,50, 0
salt_water=6, 20,30,50, 0
intermittent_water=20, 20,30,50, 0
wetland=6, 0,0,0, 0
area_a=-1, 20,20,20, 0
area_b=-1, 30,30,30, 0
area_c=-1, 40,40,40, 0
black=0, 0,0,0, 0
white=0, 0,0,0, 0
red=0, 0,0,0, 0
lightred=0, 0,0,0, 0
green=0, 0,0,0, 0
blue=0, 0,0,0, 0
lightblue=0, 0,0,0, 0
yellow=0, 0,0,0, 0
purple=0, 0,0,0, 0
cyan=0, 0,0,0, 0
peach=0, 0,0,0, 0
orange=0, 0,0,0, 0
marsh=0, 0,0,0, 0
user_a=0, 0,0,0, 0
user_b=0, 0,0,0, 0
user_c=0, 0,0,0, 0
CM_city_block_yellow=0, 0,0,0, 0
CM_city_block_blue=0, 0,0,0, 0
CM_city_block_green=0, 0,0,0, 0
CM_city_block_peach=0, 0,0,0, 0
CM_city_block_orange=0, 0,0,0, 0
CM_city_block_purple=0, 0,0,0, 0
CM_bank_area=0, 0,0,0, 0
CM_Hospital_ground=0, 0,0,0, 0
CM_Hospital=0, 0,0,0, 0
CM_paved_area=0, 0,0,0, 0
CM_medium_strip=0, 0,0,0, 0
CM_planted_area=0, 0,0,0, 0
CM_garden_path=0, 0,0,0, 0
CM_House=0, 0,0,0, 0
CM_School_ground=0, 0,0,0, 0
CM_School=0, 0,0,0, 0
CM_Commercial_establishment=0, 0,0,0, 0
CM_place_of_worship=0, 0,0,0, 0
CM_Hotel=0, 0,0,0, 0
district.1=8, 255,186,136
district.2=8, 255,206,136
district.3=8, 255,186,156
district.4=8, 235,206,156
district.5=8, 235,206,136
district.6=8, 235,186,156
city_park=4, 0,25,0, 0
state_forest=3, 0,25,0, 0
National_Park=3, 0,25,0, 0
city_forest=1, 0,25,0, 0
airport_ground=4, 25,25,25, 0
airport_runway=2, 75,75,75, 0
building=0, 25,25,25, 2
cemetery_ground=5, 0,25,0, 0
industrial_area=2, 25,25,25, 0
Railway_area=7, 0,10,30, 0
recreational_area=0, 0,0,0, 0
Shopping_Center_Ground=0, 0,0,0, 0
railway=2, 60,20,0, 100,80,80
label_road="", 255,255,255
label_roadlt="", 165,165,165
label_settlements="", 255,255,255
label_poi="", 255,127,255
label_address_point="",255,255,255
road_shield="", 255,255,255
road_box="", 255,255,255
shield_fill="", 0,50,200
shield_border="", 255,255,255
box_fill="", 120,0,0
light_shield="", 0,135,50
light_shield_ext="", 0,50,180
roadlabel_fill="", 0,0,0
roadlabel_frame="", 150,0,0
roadlabel_stick="", 150,0,0
oneway_arrow="", 50,170,170
label_road_bubble="", 0,0,0
alpha_arrow=5
3d_tunnel_color_morph_percent=50
planned_road="", 110,96,179
planned_road_ext="", 66,58,108
planned_road_visited="", 88,77,144
planned_road_visited_ext="", 66,58,108
planned_road_future="", 88,77,144
planned_road_future_ext="", 66,58,108
planned_road_prohibited="", 120,0,0
planned_road_prohibited_ext="", 120,0,0
planned_road_inactive="", 0,80,80
planned_road_inactive_ext="", 0,80,80
planned_road_hnr="", 100,100,255
planned_road_hnr_ext="", 50,50,120
planned_road_alt1="", 32,128,0
planned_road_alt1_ext="", 32,64,0
planned_road_alt2="", 0,0,0
planned_road_alt2_ext="", 0,0,0
planned_road_alt3="", 0,0,0
planned_road_alt3_ext="", 0,0,0
planned_road_alt4="", 0,0,0
planned_road_alt4_ext="", 0,0,0
itiner_highlight="", 0,0,0
itiner_highlight_ext="", 0,0,0
blocked_road="", 120,0,0
blocked_road_ext="", 120,0,0
tmc_event_color0="", 120,0,0
tmc_event_color0_ext="", 120,0,0
tmc_event_color1="", 120,0,0
tmc_event_color1_ext="", 120,0,0
tmc_event_color2="", 120,0,0
tmc_event_color2_ext="", 120,0,0
tmc_event_color3="", 120,0,0
tmc_event_color3_ext="", 120,0,0
tmc_event_color4="", 120,0,0
tmc_event_color4_ext="", 120,0,0
[other]
texture="gfx/night/texture.spr"
sun="gfx/night/sun.spr"
sky="gfx/night/sky.spr"
heightcolormap="$skin$/common/nightheightcolormap.bmp"
background_picture_0="sky_night.bmp"
background_picture_1=""
background_picture_2=""
background_picture_3=""
background_picture_4=""
sun_picture_0=""
sun_picture_1=""
sun_picture_2=""
sun_picture_3=""
[font]
default="default"
defaultbd="defaultbd"
[icon]
poi="gfx/night/poi6x6.spr"
poi2="gfx/night/poi26x26.spr"
poi2tc="gfx/poi26x26tc.spr"
settlements="gfx/telepules.spr"
trackinglist="$trackinglist.spr"
flags="skin_night/small_flags.spr"
pins="pins.spr"
gpspos="skin_night/carpos.spr"
cursor="cursor.spr"
cursor_big=""
cursor_places="skin_night/cursor_places.spr"
cursor_places_big=""
cursor_poi="cursor_poi.spr"
cursor_tmc="cursor_tmc.spr"
car="$daycar.spr"
carghost="$daycarghost.spr"
guidancearrow="$nightguidancearrow.spr"
[userpoi]
font="default"
fontsize=10
color=255,255,255
[track]
1=200,0,0, 255,255,255
2=255,85,0, 255,255,255
3=0,240,0, 255,255,255
4=224,0,0, 255,255,255
5=0,213,255, 255,255,255
6=0,0,255, 255,255,255
7=128,0,255, 255,255,255
8=0,255,0, 255,255,255
9=240,240,0, 255,255,255
10=255,198,0, 255,255,255
[model]
car="car.mdl"
car_ghost="car_grey.mdl"
; Roadsign sprites, used when [3d_config] roadsign_bitmaps=1 in SysConfig
[roadsign_sprites]
; Sprite names, should be in theme folder
main="street_name_main_night.spr"
left="street_name_left_night.spr"
right="street_name_right_night.spr"
leg_left="street_name_leftleg_dn_night.spr"
leg_mid="street_name_midleg_dn_night.spr"
leg_right="street_name_rightleg_dn_night.spr"
font_color=224,224,224
I have got this installed thanks to Darkoz's download (top work mate!). I much prefer this to the Igo 8.3 software.
The one niggle I have is with the speed camera warnings. On IGO 8.3 if the speed camera audio warning went off I couldmanually mute it by pressing the camera warning logo on the screen.
When the warning goes off on Primo 1.2 I am unable to mute it. I either have to slow right down or have the audio warnings off (something I don't want to do).
Is there any way I can get the manual warning mute working on PRimo as it did on Igo 8.3?
Any help appreciated!
