1 - 6 of 6 Posts
I bought an 03 325xi a month ago. I didn't drive it over the weekend I got in it on Monday to find it won't start. All the accessories work ( lights radio etc) but the engine won't start. I tried to start it for about 5 minutes waited 10 min then tried again. Anyone have this problem before or have any ideas?
yes! and if the battery over 3 -4 yrs... time for a new one... i have recharged my battery couple times.. but it still dies off on me... so i need new battery!
I had issues at one point with bad spark plugs/ignition cois but def sounds like ya should get the battery checked out and who knows but ya have alot of things that can affect it starting...
Does the engine turn over ok?
If it does, check you MAF sensor to see if the little "steel plate" inside it is intakt.
And measure your battery (Volts)
It could be other thinks, but these two are easy checks.
Discussion Starter #6
I replaced the battery. The car still wouldn't start so I took it to a shop and they replaced the starter and now it works fine.
1 - 6 of 6 Posts
