1 - 5 of 5 Posts
If i get a single JL 12w6v2 subwoofer in an enclosed box and the JL 500/1 amp, where is the best place to mount the amp? I plan to remove the HK subwoofers from the rear deck and mount the amp up there, but i'm not sure if that will block the bass from going through the rear deck. Any suggestions? :confused:
Discussion Starter #3
Cali6869 said:
I just got my w6 yesterday, Im removing my hk subs to use that as a port. I think its better not to block it.
so where are you putting the amp instead?
Well Im either going to put it on a custom rack where the spare goes... with a plexi on top...or might put the amps on the box.
Then hide the box behind a panel, and a neon in between. Im getting it installed next monday.
1 - 5 of 5 Posts
