1 - 8 of 8 Posts
frequent tire purchaser
I have HK and want to keep it so I was thinking of going with an FM Modulator. I would also like to have a controller small enough to fit in where the ashtray is currently. I want to steer away from putting it in the storage spot below the deck because I plan to put gauges there. Does anyone have any recommendations on what I should go with for a controller/hardware and maybe any alternative installs?
TIA,
Mike
Discussion Starter · #3 ·
That would mean that I had to add a changer at the same time. I wasn't planning on doing that, but I guess I could if that was the best way..... it's just that it would cost a lot more than what I want to spend.
check out KBMWSIR
It doesn't appear that you would need to add a changer for it. It just uses the existing audio connection for sound and the radio controls to control it. It does seem like you would lose the display though.
Discussion Starter · #5 ·
I'll call them.
Thank you,
Mike
I also believe you don't need to add the changer -- the purpose of the adapter is to connect an auxillary device (e.g., Sirius) through the changer interface and thus get it's full sound quality vs. the limited FM modulator route.
Discussion Starter · #8 ·
What's a little while? That would be perfect.
1 - 8 of 8 Posts
