1 - 4 of 4 Posts
'01 330ci 258kmiles
Hey guys hoping someone has an answer to my problem here. My gauge cluster has seemingly started to malfunction. The odometer has stopped working as well as the light fixtures for my coolant temp and tach. The tachometer however stays illuminated even after turning my car off, toggling the light switch also does nothing for it. It's an '01 330ci
927854
Administrator
2004 330Ci 115k miles
Sounds like you need a cluster repair service.
Have you run the TEST 02 - Cluster System Test?
I'd be doing as BD recommended. See if the matrix lights up fully during the self test mode?
If not sounds like a cluster repair is in order.
1 - 4 of 4 Posts
