1 - 4 of 4 Posts
I've got two Audiobahn flame subs, and two rockford fosgate 500.2 watt amps. Each amp is for each sub, and I have to wire each amp to each sub BRIDGED. (at bridged I get 500X1 @ 4 ohms)
Can anyone give me instructions, or maybe a little diagram of how this should be done propperly?
Thanks in advance :thumbup:
Discussion Starter #3
dual 4 ohm. However, I don't want to send each amp to both speakers. I've heard the best results come from wiring them up bridged individually to each amp.
Anyone??
you can't, you bought the wrong subs....
Your only options for wiring those subs individually is series or parallel - therefore you can only present a 2 or 8 ohm nominal load to each amplifier. Neither of those loads are optimal for the amplifiers you have selected.
check out the tutorial section at www.jlaudio.com for more info on how to wire dvc subs, they have an excellent walkthrough..
1 - 4 of 4 Posts
