1 - 6 of 6 Posts
need help, advice, guidance
I have a 99 328i automatic trans and was wonder if I can swop the trans out of a manual 2002 325i. With no problem.
Really?I
You have an automatic '99 328i and you want to swap in a MANUAL trans from a 325i?
This is called a manual swap. It's quite involved..mechanical, electrical, & coding.
Have a search.
I would also suggest you put a topic in your post titles...Not help
2003 325xi 5spd Manual
New driveshaft, coding, decent amount of labor involved. And if yoy dont swap the gears in the diff, it will suck driving the car.
Shifting
Find one from a 328. You'll need to do coding and get a new diff to match the new ratio of the transmission
OEM ///PLUS
2003 M3 6MT Slicktop
well i wouldn't say a diff change is "needed" per se. nor would i say "it would suck" with a 3.46. especially since the 323Cic, 323iT, 325Cic and 325iT all come from the factory with the 3.46 with the five speed manuals.
also a lot of performance oriented 323, 325, 328, 330 owners swap the 3.46 in their manuals for more pep.
but agreed it may not be desired by some and a good point of things to consider in the swap. :thumbup:
1 - 6 of 6 Posts
