1 - 3 of 3 Posts
I need help guys, so last nite i put on my NEW steering rack everything went well, but when it was time to but
the fluid it started to squirt out everything from a hose where you bolt it on the hose was tight. what can it be?
the hose is #7 on the picture
should i buy a new hose? or a new washer?
HELP!
THANKS
Did you placed the washers in front and back of the banjo bolt of the hose? If you did maybe new washers might be needed. Hopefully it is just washers and not a busted hose. Good luck.
1 - 3 of 3 Posts
