You should browse our Important Links sticky thread.I can’t find any wiring digrams/schematics for this car in English.
Most likely the COM port that Windows assigned to the cable changed and you did not edit the config file accordingly. See this post.why I would all of the sudden not have communication with INPA?
Maybe a bad cable?still don't get the any communication in INPA
You did not install the software correctly.@Bali i finally got my new cable in and inpa works great however when i go into win kfp to attempt the dme re-flash its as if there are not any files when i select update zusb in the ecu family and zusb columns there isnt any info.
You cannot code out secondary air system.how can I tell if my secondary air system has been coded out?
