+1 not enough boost for low compression motor.At that boost and compression, I'll guess ~ 350 rwhp.
I'm really confused with that postmore than you can afford pal, 10.5psi
teaseI haz vid.
Are you sure that zhp wasn't an automatic? Sounds really low for a dynojet! Maybe they need new bearings on the roller? That's REALLY low.Ok, so I have no access to my dyno sheet on my phone... but I dyno'd on a dynojet that has a stock zhp at 184whp....
Than it's not set up right. The power absorbers add inertia to the drum which explains the lower power reading. Dynojet software will calculate for this if it's installed properly.Loadable dynojet, reads lower for some reason.
