OK, guys my car has the wierdest quirk ever...
I put on my Hamann exhaust and the day after doing so my car has on three different occasions seemingly stalled out while driving. What seems to happen is that when I shift gears from say second to third at thirty five miles per hour (*or fast or slower speed and rpms don't seem to make a difference) the rpms will suddently drop down to zero, the powersteering turns off **(i almost crashed the first time it happened because I was going around a turn as it did such), the check engine light in addition to the oil light and battery light turn on and everything else (radio, interior lights) seems to be fine.
Does this sound as though the car is stalling? Would the exhaust be the culprit (*my friend had an alfa romeo that did this the problem ended up being the fuel pump)... do you guys think its the fuel pump/exhaust/what? If I take it to the dealership (the car still has its warranty but now has a Hamann exhaust on it) do you think they will blame it on the exhaust and basicly tell me that I'm out of luck and that they won't fix it under warranty? Should I take the car to Midas (where I had the exhaust installeD) and see if they have any ideas? Should I take the exahust off, put the stock one back on, take it to the dealer, and tell them that the car has been acting up lately and see if they find anything wrong with it? What do you guys suggest...
Could puting an ECIS intake and a Hamann exhaust actually have done something wrong to my car (I did buy the exhaust used). Do exhaust systems go bad after a certain millage (mine had 15k miles on it from the previous owner).
What do you guys suggest... I'm in a real bind... That being said, the exhaust does look sick :woot:
Please help!
Please help!
