1 - 7 of 7 Posts
Pwner
My passenger side back window won't come up anymore for some reason. it makes noises when the button is pressed, but it won't really move. also, if you tug a little on the window, it moves up some, but then stops and won't move no matter how hard you pull on it. i almost never use the back window so i don't really want to get it fixed right now, but i need to get it up. is there any way to make it go up easily or is this an easy fix? i don't want someone to jack my ipod or rain to get in the car. Thanks!
Pwner
Discussion Starter #2
Please help! someone might steal stuff overnight from my car!!! its sitting in my apartment parking lot....
www.piratecove.org
replace your window regulator...either yourself...or by the dealer.
you might be able to pull it up in the meantime...but for the most part your window is dead
Pwner
Discussion Starter #4
How much should that cost?? if the regulator was broken, would it continue to make noise when i press the button? it seems like just a connection is broken..
Beware of pwner
If you are still under warranty, it should be free.
When my window regulator went bad, it started making a grinding noise. I called BMW of San Diego, and they were able to fix it the same day.
Pwner
Discussion Starter #6
1 - 7 of 7 Posts
