Yep, it may only apply to mini coopers (that is what I was programming), so may not happen to everyone. Hope the instructions go well, the file is insanely large haha. I had to upgrade my hard drive in order to fit ISTA+ and ISTA/p on my laptop.
Step 2: Pre-Install Folder
Install the corresponding items in the Pre-Install Folder Note:If you have newer versions of Microsoft Visuals, and Java the only ones you need to install is Registration Entries (6 thru 8).
1: Microsoft Visual C++ 2015 Redistributable (x64 - 64bit) - 14.0.23026
2. Microsoft Visual C++ 2015 Redistributable (x86 - 32bit) - 14.0.23026
3. Microsoft Visual C++ 2015 Redistributable (x86) - 12.0.30501
4. Microsoft .NET Framework 4.5.2
5. Java
6. Don't Need
6. Registration Entries
7. Registration Entries
8. Registration Entries
Step 3: Move Rheingold folder
Move the folder to C:\EC-APPS Note: You can place the folder as-well in C:\Program Files, or wherever you'd like. I personally like having it in EC-APPS because its easy to find. View attachment 970080 Step 4: Create Shortcut
Create a shortcut for IstaGUI.
In this example, I decided to drag the shortcut to my Desktop. View attachment 970084 Step 5: Launch ISTA
Once ISTA is launched, complete the setup. View attachment 971128
Press - Next
Note: You don't have to enter anything in this screen View attachment 971129
Press - Next
Copy and Paste the License Key into the empty box labeled licenses:
Note: This License Key can also be found in Pre-Install Folder (rheingold-license.txt)
Press - Next
You do not have to enter anything in the ISIS.
-> SIMPLY press the X in the top right, and exit the program. View attachment 971132
Lastly restart ISTA and head over to VCI Config.
(This can be accessed via pressing the Wrench ICON on the toolbar above.)
Select Edibas Default Settings (Edibas.ini)
-> This is used for E-Chassis (BMW) and R-Chassis (Mini)
Select Dealer Organization ICOM/ENET Local Area and ISIS Network
-> This is used for F/G - Chassis (BMW)
-> Tutorial: How to connect and use ENET View attachment 971133 Cheat Sheet: If you are not sure what cable you need. Note: K-Line, and K+DCAN is EDIBAS.ini View attachment 970088
Congrats! You have installed ISTA/D 4.01
Enjoy!
If you have any issues, please let me know in the comments.
Thank you for all the effort you've put into this! I'm running into a problem when I first launch ISTA+ following the installation. INPA installed already and running correctly. Has anyone encountered this before? Thanks
Thank you for all the effort you've put into this! I'm running into a problem when I first launch ISTA+ following the installation. INPA installed already and running correctly. Has anyone encountered this before? Thanks View attachment 973179
Sorry for the late reply, its been a busy weekend!
I have had this issue before!
Solution:
Step 1: Uninstall ISTA (and any files related to it)
Step 2: Download RCleaner -> Link
-> Once that is complete, you can reboot your PC
Step 3: Try reinstalling ISTA, and see if that fixes your issue!
Solution:
That did the job and it appears to have installed successfully - thank you! I won't get a chance to go out to the car ('04 330Ci) and see how much trouble I can get myself into until next weekend, but I'm looking forward to poking around and seeing what I can learn. It's got a couple of bugs that are driving me up the wall and now I hope I'll be able to chase them down.
Solution:
Solution:
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
