81 - 100 of 123 Posts
· Registered
@vaah
Great News! I have found an earlier version 4.01 (Which is compatible with Windows 7).
I learned that versions 4.21 and above is only compatible with Windows 10. :rolleyes:
I'll be making some new install instructions for Version 4.01, and readding v4.32 soon as-well.
I apologize for all the frustration, I know its a PITA getting a version to work.
What a surprise!! I'll give it a try. I'm downloading it now. Thank you for the effort!
· Registered
323iT - 323Cic
Discussion Starter · #84 ·
@tbouchard991 Hello I ran into problem. What do I fill in for the home ISIS field? I tried random string, it gave me error..
Error message:
EDIT: Looks like I spoke too soon. lol, I just relaunched the app, it works fine. Now I'm off to my car to try read any errors.
Awesome! Glad you got it to work. (I'll add that to the troubleshooting guide)
· Registered
Install Instructions: ISTA+ v4.32.15
Requirements
  1. Windows 10 v1903 or higher, 11 (32-bit or 64-bit)
    -> Windows 7/8 is NOT supported!
  2. K+DCAN Cable (I recommend Pro K+DCAN Cable from BimmerGeek)
    -> Amazon/eBay cables are hit or miss
  3. BMW Standard Tools MUST be installed, and working correctly!
    -> How to Install BMW Standard Tools
  4. 150GBs or more availble space on your Hard Drive or SSD.
    -> I have tested it w/ 140GB's, and it would throw an error.
  5. Syst
Min 5Gb of RAM / Memory.
· Registered
323iT - 323Cic
Discussion Starter · #96 ·
4.1 - I have an old version of Windows so I can run INPA/NCSExpert - don't I have to use the older ISTA?
Ill take a look at the file when I get home in a few hours. My apologies for the issue.
· Registered
323iT - 323Cic
Discussion Starter · #98 ·
Good News!
I stumbled upon another version of ISTA 4.32.15 which has Service Data.
Note: ISTA+ does not program E-series.
-> Will be uploading soon.
Rectangle Font Screenshot Parallel Number
I also am testing a version of ISTA/P and once I get that confirmed it works I'll upload it.
Also to clarify ISTA Versions:
Credit: Almaretto @ Bimmerfest
E-Series & R05x Mini:
  • Interface = K+DCAN Cable (OBDII to USB) or ICOM
  • ECU Data Files = SP-Daten
  • NCS Expert = Coding Software
  • WinKFP = Programming (Flashing) Software
  • EDIABAS = Low Level ECU Communication Software used by NCS Expert & WinKFP
Fxx- / Ixx- / Gxx-Series, Mini (F05x/F06x), & Rolls-Royce:
  • Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM
  • ECU Data Files = PSdZData
  • E-Sys = Coding Software
  • E-Sys = Programming (Flashing) Software
ICOM
  • ICOM A: main interface
  • ICOM B: adapter for programming multimedia in E series
  • ICOM C: adapter for old BMW with round 20 pin diagnostic plug
  • ICOM D: adapter for motorcycles
Additional Dealership Level Software
  • ISTA+ (AKA Rheingold or ISTA-D)
  • ISTA-P
    • PROGRAMMING traditionally for all chassis, but F-/I-/G-series phased out with 3.63.5 release (March 2018).
    • ICOM Recommended. An ICOM emulator with K+DCAN or ENET can be used, but will NOT communicate over all protocols to program every ECU.
    • Replacement ECU's must be NEW
· Registered
Good News!
ICOM
  • ISTA-P
Ista+ is not letting me use programming, any idea why this would be? is there a special setup? I have an ICOM Next.
Also I got Ista/P from a utorrent download but there is a weird problem: The terminal 15 voltage keeps cutting out to 0.0V. because of it the DME might be bricked..
· Registered
323iT - 323Cic
Discussion Starter · #100 ·
ISTA+ in the current download doesn't have the SDP for Programming.
What are you trying to achieve w/ ISTA/P?
