21 - 40 of 197 Posts
· Registered
323iT - 323Cic
Discussion Starter · #24 ·
it seems that the download from dropbox gives up after 13.62GB, not sure what is going on. Also, I am unable to unzip the file in DropBox... Any insight?
Possibly might be an issue on your end?
  • What message or error do you get when the download fails?
  • What browser and operating system are you experiencing this on?
  • Is your network stable?
I downloaded the file on my side and I had zero issues (from my laptop / desktop)
· Registered
I tried and it looks like my connection was timing out at some point during the download. I saved the file to my own dropbox account, downloaded the Dropbox app, and was able to sync it to my local drive.
Now, I went to try and do the same with ISTA-P, but it seems that the link is now to an Orangedox account, which won't let me save it to my dropbox. Any insight?
Sorry for being a troublemaker, your assistance is very appreciated!
· Registered
323iT - 323Cic
Discussion Starter · #27 ·
The file keeps failing to download from Orangedox, I have steady connection. Kinda weird. Do you have a different link or a different file hosting site you use?
Weird!
I replaced the Orangedox Link with the original Dropbox Link.
@MasterDuke - @j.desgroseilliers
Let me know if that works. Only reason I used OrangeBox was to track analytics of downloads.
If it needs to be ill split the DL link into portions, and upload it so DL size is smaller.
· Registered
2005 330i
@tbouchard991
Interesting, I downloaded the Dropbox link and was still having the same issue opening the .7z file. I tried to extract it without opening the file, just right clicking, and it worked! I have yet to get it on my laptop, but I will be trying it sometime tomorrow, along with some diagnosis testing. If any issues arise, I'll be sure to post a reply. Thank you for this helpful software!
· Registered
323iT - 323Cic
Discussion Starter · #29 ·
@tbouchard991
Interesting! Maybe Ill upload it as a rar file, instead of a .7z.
My apologies for the issues!
· Registered
323iT - 323Cic
Discussion Starter · #31 ·
When I'm using DCAN cable to run ista, the vehicle test takes lots of time, wonder if you guys experiencing this too? Will change to enet cable help?
That's a good question! Im not too sure.
It takes a bit of time to do vehicle test on my side as-well.
· Registered
Hello, i tried to install ISTA+ on my windows 7 laptop. But the installer won't let me. It said my windows version isnt supported. My c drive has about 200gb free space. Any suggestion?
Edit: OP's guide mentioned win7. But it looks like ISTA+ will only run on windows 10.
· Registered
323iT - 323Cic
Discussion Starter · #35 ·
Oh, that is interesting! I'll edit the post for the mean time and ill look into it.
· Registered
Hello I ran into problem, I have K+DCAN that doesn't have switch on it. ISTA+ gives me error "The vehicle could not be identified successfully. Check vehicle interface and 'PAD actice'."
This cable works when I use INPA on my other laptop that runs windows 7. I guess the cable itself should be fine. So not sure what's wrong. Can you help me?
I already changed the line "Interface = STD:OBD" in EDIABAS.INI file. still not working..I also tried this setup on BMW E60 520i 2004. It doesn't work either.
· Registered
323iT - 323Cic
Discussion Starter · #37 ·
Is your port in the EBIDAS.INI set as the same as the hardware?
Interface =STD:OBD
Simulation = 0
EcuPath =C:\EDIABAS\ECU
SimulationPath =C:\EDIABAS\SIM
TracePath =C:\EDIABAS\TRACE
TraceSize = 1024
Interface must be set to the above not ENE or any of the
other of the 3 possibilitys for Interfaces.
OBD.ini in the Windows directory must be set to the
same port as you use in device manager
[OBD]
Port=Com9 (This can be set to whatever port is open, I believe mine is set to COM1)
Hardware=USB
RETRY=ON
· Registered
I coildn't find PORT definition in EBIADAS.ini, but I had changed interface definition to "Interface =STD:OBD"
I haven't changed OBD.ini though. Where can i find this? Is it in ista+ installation folder?
Also, i read again pin 7 and pin 8 my K+DCAN cable has to be bridged for <2007 car year? Is this true? My cable doesn't have switch.
· Registered
haha i think i am right behind you in getting this configured. Got ISTA installed and my K+DCAN arrived today. Mine has the switch. But not connecting to the car. same error message as you. Just saw your previous post so went in an edited the EBIADAS.ini to STD:OBD but i can't find any OBD.ini file. Did search of entire drive. My USB port is COM3 for the cable. And don't see anything in ISTA to manage that configuration. Hoping TBOUCHARD can guide us to the light!
· Registered
Yeah, I just checked my windows I didn't find OBD.ini under windows folder, or in ISTA installation folder. I did search the whole C drive, not found. I'm waiting for @tbouchard991 for his next advice.
