1 - 10 of 10 Posts
How do you remove the glove box?
I did a search in the DIY forum... but nothing turned up...
Anyone have a diagram?
I've taken all the top front screws out, two screws behind the door latches and 4 that are part of the hinge for the door underneath... Its still stuck in there... It seems like I'm missing one screw somewhere....
thanks!
Check out the DICE install DIY. It has very detailed removal instructions (although I will say that there was some variation between the screws in my year vs. the one shown in the guide).
Discussion Starter #5
Try this. Scroll down to the Glove Box removal section. These instructions worked for me when I replaced the final stage resistor.
http://www.circlebmw.com/service/access/9410794.htm
Michael
I removed the 6 screws the diagram shows but it says nothing about the straps... It Still wont budge and I don't want to break anything... Do i even need to take the door off or will the whole glove box and door slide out?
Arr!
Discussion Starter #9
Thanks everyone for all the info above...
NOW: HOW DO YOU REMOVE THE "plate with floorboard light"
ARRR!!!
1 - 10 of 10 Posts
