1 - 4 of 4 Posts
SBBMotorwerks
I need to help a buddy swap his steering wheel....he has the non-sport (4-spoke) steering wheel.....how do you remove it?
Thanks!
1.888.JLEVISW
Do a search in the DIY section for the exact procedures cause I found some, but I believe u use a torx driver to unscrew four torx screws in the back of the steering wheel and the airbag should pop out...then use a wrench to undo the middle bolt and your done...I believe this is how it's supposed to be done but check the DIY section cause there is a good writeup about it...
Flex UK Style
Before you do anything, disconnect the battery. That way, when you re-install the wheel, or put in the new wheel, the airbag reset light won't go on.
SBBMotorwerks
Discussion Starter · #4 ·
OK, i found a DIY.....
1. Disconnect the battery
2. Remove the torx screws holding in the airbag
3. Remove the bolt holding on the steering wheel
Is this correct? I have heard that the round airbag has spring clips holding it in, while others have torx screws....is this right?
Also, what are the sizes of the torx and nut? I assume they are the same as the M wheel: #20 torx, and 10mm nut driver
Can someone confirm?
1 - 4 of 4 Posts
