1 - 2 of 2 Posts
I need help ASAP.
How do you remove a half broken lug bolt in rim?
What should i tell the shop to do?
Cost for removal?
Well, if you remove the wheel entirely, you should have a short stud sticking out from the hub. You should be able to use vise grips and remove the stud.
If it's broken below the surface, try using a bolt extractor.
Worse case, you'll have to remove the hub.
1 - 2 of 2 Posts
