I recently replaced most of the cooling system I.e. Expansion tank and sensor, radiator, top hose, fan clutch, as well as the thermostat. The radiator light came on last Friday so I topped it off with fluid. I drove it for about an hour and the light came on again and due to prior experiences with this issue I thought I had a slower leak than what i did. I kept driving it because he temperature gauge was still in the middle (normal) but apparently it was running more hot than I thought. I'm not completely sure but I believe the leak came from the bottom of the expansion tank as maybe it was not connected properly. At any rate... I'm car less and wondering how to check if I damaged the motor or not. Please advise...
When you say you topped it off...you mean you filled the ET all the way to the top with coolant, or just to max...meaning that you knew how to fill ET and stopped adding coolant just when the top ball on ET stick came all the way up?
Start reading cooling threads if this is confusing.
Based on what you said, though...seeing no reason to suspect HG...at most...sounds like you might have just sprung a coolant leak...as others have said.
You don't have a radiator cap to open...first of all...second of all...if you open it up with car running...it will gush out...and right now, I have no idea whether you just didn't bleed properly, didn't install stuff properly, replaced the ET cap, or what.
But, it just sounds like you have a leak...maybe cracked the ET again coz you overfilled it...or if really unlucky, maybe sprung a leak elsewhere like the rad...only speculation.
Not seeing HG...and don't think opening up valve cover will help at all in any case. You're of course welcome to do compression test or anything you want...it's your car...but personally, and nothing personal...
Think you should read lots of diys on cooling here and get up to speed on it. It's different than the designs of most cooling systems...but MB and Jaguar, I know, both also have an expansion tank...not an overflow tank that sucks coolant back in...it's a different design is all I know...so don't base what you do on what you know from other cars...
Cribs: read and study cooling threads a lot!
Doug
