1 - 10 of 10 Posts
I hear a slight popping from the suspension if the wheel camber position changes due to a bump when its cold... also if i give the brake pedal a tap the steering wheel jerks. The car has 23k on it.
Put it on the rack and pull the wheels and try to move them in a direction that they were not made to move. If they move seven slightly then your ball joints may be going. 3 series are notorious for ball joint problems.
Is NOT A Mechanic
my ball joints were shot - the car creaked/popped when the wheel was turned while moving slow or stopped. There was also masive uneven wear on the tires. My Control arm bushings were also gone - that caused vibrations and clunking.
Those symptoms of worn out control arm bushings and possibly ball joints.
Clunking
Hey, I just did my front brakes the other day, and I noticed that at times, usually when I'm braking, I hear a "clunk" from under my side of the car. At first, I thought it had something to do with my brakes, but it sounds like something else is loose under my car by the suspension - I just had my front control arm bushings replaced about 5 mos. ago. What could else causes this noise?! :dunno:
i may be having similiar symptoms and i have a 323i, was wondering, because i am going to purchase a coil over kit for the car would that solve these problems or is that a whole other issue ?
23K miles????
Is any one model year more susceptible than others? Or is it endemic to the whole series?
I hate it when my car needs repairs :bawling:
323CIBOY said:
Hey, I just did my front brakes the other day, and I noticed that at times, usually when I'm braking, I hear a "clunk" from under my side of the car. At first, I thought it had something to do with my brakes, but it sounds like something else is loose under my car by the suspension - I just had my front control arm bushings replaced about 5 mos. ago. What could else causes this noise?! :dunno:[/QUOTE
It's probably the ball joints.
Discussion Starter #10
wow, i cant believe the ball joints are going at this mileage.
1 - 10 of 10 Posts
