1 - 14 of 14 Posts
Can you guys show me any post of website showing how to take the headlight out?
Peter
Discussion Starter · #2 ·
I tried to unscrew all 4 nuts and it seems to me that the lower eyebrow need to be taken out before the headlight assmebly comes out. Is that ture?
I can only lossen the clip on the inner side of the lower eyebrow, but have a hard time getting the outside out. CAn you guys help?
Peter
Peter
Not sure about the M3 but the sedan requires the bumper to be at least loosened.
Discussion Starter · #8 ·
So you mean I need to take the lower eyebrow out before taking the headligh assembly out?
You mentioned there are some clips, but how can I reach the clip if my headlight assembly is on top of it?
Can you (SymbionM3) take some pics on how to remove the lower eyebrow as well as the headlight if you can?
GarrettF, I looked at several DDE installation guide and most of them just have a little portion descriping how to take the headlight out, most of the part on emphaisis on how to install the DDE.
I treid to pull the eyebrow out, but I can only get the inner part out, cannot get the outer part (near the signal) work.
Peter
Discussion Starter · #12 ·
The problem that I have is how to remove the lower trim under the headlight. I have a hard time getting it out. It meantioned take the trim out using a screwdriver but how? Where's the clip and how can I access that?
Peter
Premium Member
You do not have to loosen the bumper to get the headlight out.
Did you look at this?
http://www.e46fanatics.com/howto/howtodetail.php?howto_id=10
start at #9
To get the bottom part off of the fender use a flat screwdriver and pry the back of the clip off of the fender. If you look in the hole where the corner light goes you can see the back of the clip. Look at this picture to get an idea of what the clip is connected to
<img src="http://performanceix.com/howto/images/10/35.jpg">
you can pop the clip out from the back side by prying it.
Tim
start at #9
Tim
When I did mine, I did remove the bottom trim but the angle of the screw between the light and the bumper was too much. Is the clip on bottom trim what you were referring to? Keep in mind, I did not completely remove the bumper, i just loosed the left side and slide it toward me a little.
1 - 14 of 14 Posts
