1 - 3 of 3 Posts
I did found the white connector but it only has one cable connected to it (the brown one). When I turned the key to position 2, the indicator light of the homelink wasn't on.
Is the connector supposed to be connected with 2 cables? Thanks
Wrong cable, you will find like 3 or 4 different connector in there, go deep right toward passenger side, and pull out that cable. it will fit perfectly into the homelink, if not keep digging.
1 - 3 of 3 Posts
