Thank you for the post OP. Nice to have a long list of 'info' all in one place!
I'm guessing someone didn't hook the Panasonic up right. Either hooked it to the HK amp or tried to bypass the HK amp incorrectly. IOW, it's improbable that all the speakers are blown...hold off on buying replacements for them just yet (sorry HalstonI just picked up an 04 330ci with the h/k system. There is an aftermarket panasonic head unit installed and it sounds absolutely disgusting. I can't even turn it on without cringing.
I'm not sure if it's wired incorrectly or if all the speakers are blown, but i have no idea how this system works. Can a 4 channel head unit with a sub out properly connect to all the speakers? i know there's a lot of discussion about wiring but to be honest it's all over my head.
I want a simple fix, i dont need car show quality sound but i listen to A LOT of music and i just need it to sound good, not impressive. What i really want to do is find an oem head unit, preferably the exact one that came with the car originally. I was under the impression that it was something other than the "business cd player" but am i wrong? I thought maybe there was a h/k head unit. Let me know if a business cd player will be a proper fit for oem quality sound.
thanks for the detailed write up on wiring. one day when i'm not afraid to rip my new baby apart i'm sure it'll come in handy.
Does anybody know the crossover frequencies on the front door speakers? I'd like to go with a set of separates up front (because the stock HKs rattle [blown?]) ... and ideally, I don't want to run new wires.
If I knew what frequencies were sent to each of the 3 speakers in the door I might be able to use them.
When you lower the ohms you essentially "open-up" the amp, possibly burning it up from higher heat generation. That said...smaller speakers don't cause as much problems as bigger ones, so the mods aren't as bad as if you were doing woofers. And going from 3 to 2 ohms isn't tooooo bad, although it's almost doubling the flow (1.5 ohm would be doubling it because it's half of 3).Hate to bump an old thread....but what would happen if you replaced the factory HK 3 ohm Midbass door drivers with a 2 ohm 6.5 midbass driver? Assuming, stock HU and HK amp?
Well there's you go! :thanks:Above is good advice but have confidence that the output stages in the hk amps will run down to two ohms.
The spec sheet for the chip says it's designed to run 2 ohms and above.
http://www.electroschematics.com/951/tda8563q/
In the process of replacing damages or HK speakers.
I used Cdt audio CL6L 6.25 woofers in the doors (3.4 ohms manufacturers rating)
Went with vifa NE652 2inch mids.
When I went to look at the stock HK tweets... I noticed they were 4 ohms not 8 which should make the choice much easier...
So far so good on stock HK amp. The CDTs took a little finagling but they are a nice choice being a shallow Mount driver that doesn't need any cutting of door panel.
Was looking to slowly upgrade to a full active setup and bypass the factory amp... Good first step.
Sent from my Nexus 6 using Tapatalk
