1 - 2 of 2 Posts
Hi,
Since the et value of my rims dont realy fit my car im looking into higher and stiffening my back supsension (got the origanlly for my e90 but had to buy a e46 for a few reasons). Currently i have stock suspension. But is there a suspension kit to higher the car and maybe to use some suspension spring stiffeners to prevent to car from running in the the wheel arch. The outerpart of the wheel arch hits the outside of the tire.
Regards,
Bart
1980 733i, 2006 m3
Nothing bolt on comes to mind. A good spring maker could probably do something for you. Then you’ll need longer shocks. Maybe tweak the suspension / sway bar bushings. And then the handling after. That is a rabbit hole I would not want to go down. Probably cheaper to buy matching rear rims.
1 - 2 of 2 Posts
