When my car is started cold, it makes a weird high pitched noise - I can't decide if it's a whistle or a mechanical squeal. I read lots of threads describing similar issues and it seems most are either caused by pulley bearings or vacuum leaks. Armed with that knowledge I had another look and recorded a few video clips. I noticed that the noise gets louder as I crack the throttle a little, but disappears as I accelerate. Then it comes back when I close the throttle. But, the pitch doesn't go up with engine speed as you might expect it to if it was a pulley related noise. All of that makes it seem to correspond with vacuum.
Still, sometimes it does sound more like a squeal than a whistling noise. In any case it disappears completely once the engine warms up.
What do you guys think?
A clip taken from the engine bay:
https://www.youtube.com/watch?v=DsXk1hhXsEg&feature=youtu.be
From inside while driving in 1st gear:
https://www.youtube.com/watch?v=Yk5Uch51f_U
