41 - 53 of 53 Posts
Here to serve y’all
2004 330Ci 85k miles
Genuine BMW to VDO
Does it seem like the old MAF was over-reporting air mass?
I ask because I had a similar problem with negative LTFTs on a genuine BMW MAF that was less than 5 years old, and only solved it with a new VDO MAF.
Discussion Starter #42
Over reporting. Their was build up on the wire which i cleaned but I don't know how old it is so I just went brand new to save me the headache.
I have two cans of MAF cleaner here, that remain with 90% full. FWIW I've never had a satisfactory long term outcome with cleaning MAF's.
Cleaning (if it doesn't damage it) one and if there's a change for the better only proves a new one is needed.
Discussion Starter #46
I agree. I didn't get the MAF code until probably 2 weeks ago which confirmed my diag. The LTFT was high because it just "learned" to dump fuel to compensate for the "unmetered air" (oil residue) on the hot wire. The interesting part was when I got the CAN torque reduction on my recently rebuilt transmission. I had no idea the MAF would tell the ECU to limit torque. I regained a good amount of power and it pulls very nice. I still need to do my front suspension overhaul and coolant system overhaul and she'll be perfect.
Here to serve y’all
...I got the CAN torque reduction on my recently rebuilt transmission. I had no idea the MAF would tell the ECU to limit torque.
The EGS gets some important data from the DME, such as throttle position, load, RPMs. It’s not obvious, but engine issues affect the transmission in unintended ways.
2004 325i automagic
Normally the MAF should not get oiled up. By any chance, is there an (over) oiled K&N filter? Perhaps a broken airfilter box letting in unfiltered air?
Fwiw, when I had a soft failing fuel pump the DME (aka ECU) put the slushbox into limp home mode (4th gear only, could not rev above 3k or 4k rpm, and the "trifecta" lights came on), so drivibaility issues can affect transmission output in certain cases.
41 - 53 of 53 Posts
