High LTFT but normal STFT Diag - 330ci
1 reading
25K views 52 replies 9 participants last post by  Archbid
#1 ·
I was doing diag in scanmaster elm, My LTFT are 20+ and get a little better better in high rpm but my STFT always stay within range (check pics). I have already replaced the fuel pump, filter, and checked fuel pressure. All is good. My MAF readings dont increase at high RPM though, is that normal?
#9 ·
I took some more screenshots, it has the codes and more graphs. My emission isn't setting and when i get gas it always stalls on start up, could that be because the DMTL? I also included the freeze frame from lean code.
This post has been deleted
#16 · (Edited)
Don't be a douche. Please.
You can graph the MAF and determine whether it has failed. You cannot test the MAF that way. The actual reading is dependent on atmospheric pressure and conditions, which I strongly doibt you have the equipment to control. But I may be way off. The MAF fails by losing accuracy, normally by under-reporting. So it can look mostly right on the chart but be off meaningfully enough to cause fuel trims.
Resetting adaptations is not like resetting codes, though I could see how you would reach that conclusion. The ECU does adapt to the big one and sensor conditions through the LTFT, and it alters those adaptations in real time through the STFT. However, it adapts them in both directions. If you fix a vacuum leak, the ecu will lower the LTFTs. It might take a few drives, so bmw provides a reset so technicians don't have to drive your car around to see if they fixed the issue.
There is no such situation as Ltft being wildly out of range and stft being in range as being healthy. The LTFTs should be +/- 2.0, and you get codes at around 11-12%.
You had extremely high LTFTs, which means that your the ecu was dumping fuel in. You can look at the STFTs at idle and cruising speed, which can help direct your attention to fuel system/sensors versus vacuum.
But I strongly suspect that you have not quite understood that you have an old engine and if any of the precat sensors, vacuum seals and hoses, fuel pump or fuel filter are original, they should all just be replaced.
It's like your responding without even reading or maybe your getting confused. I never said resetting the adapts was anything like resetting the codes, I know the difference between the two. I never said that it was healthy. READ CAREFULLY: My STFT where IN RANGE (look at the graphs) my LTFT was 20+%. The STFT continued to be in range even WITH LOAD and the LTFT never dropped. THAT is the reason for resetting adapts. It has already learned to add more fuel which is why the LTFT where 20% but STFT stayed within range. When you reset adapts, you clear what the ECU has learned in LTFT so it doesn't compensate automatically. That why after the reset it read -25% on both LTFT and STFT because the ECU is getting to stoichiometric ratio with no learned adaptations. And I already told you I replaced the Fuel pump and fuel filter so why would you mention it again? Not trying to be a douche but your reading comprehension is not the best.
#18 · (Edited)
ScanMaster is pretty good. OP has provided some good data. It's not yet clear what exactly is the problem, although high positive fuel trims at idle is normally vacuum leaks. Maybe more background information could help us help him?
Did the engine used to run fine with no trouble codes and near 0% LTFTs?
What event triggered the current issues?
Is the engine, and especially DME software, all BMW factory stuff? No tune or other goodies here?
What did the smoke test reveal? Any vacuum leaks?
#21 · (Edited)
ScanMaster is pretty good. OP has provided some good data. It's not yet clear what exactly is the problem, although high positive fuel trims at idle is normally vacuum leaks. Maybe more background information could us help him?
I bought the car like this.
The main symptoms were: stalling after refueling and loss of power in the high end (high load). It acts like its not getting enough fuel or fuel is being cut off. Intermittent delayed throttle response.
Everything is factory.
I'm going to do a smoke test today if I can find all the materials today and I'll post results later today.
#24 · (Edited)
Here's some spit-balling thoughts...
Stalling after refueling: I wonder if fuel is getting into the evap system, say the vapor canister is saturated? Maybe remove the evap hose from the purge valve and see if liquid fuel is in there. Should only smell like fuel (vapors).
Compression/leak down tests: have we confirmed the cylinders are good?
Clogged cats: exhaust back pressure test, or simply remove both pre-cat O2 sensors and have a short drive to see if power returns.
For diagnosing fuel system issues, I like to just look at the STFTs when the engine is fully hot. They're instantaneous, so reflective of current running conditions.
Smoke test: eager to see the results of this.
Does ScanMaster do logging of PIDs? That***8217;s one feature of OBD Fusion we use a lot.
What's the production date on your 330ci? Or, better yet post the last 7 VIN numbers so we can look up the exact car configuration on realoem.com.
#25 · (Edited)
Does ScanMaster do logging of PIDs? That's one feature of OBD Fusion we use a lot.
I changed purge valve a few weeks ago and i i checked again during the smoke test and their is no fuel. Their were no leaks during the test but Im going to do another because I don't think I have enough pressure because the jar was leaking (diy smoke machine). But I pulled the oil cap to see if there was smoke and their was, so I was getting smoke in the engine. I reset fuel adapt again and and now my STFT is at 27% and LTFT is at 0%. The STFT decrease with load so it definitely a vacuum leak (look at graph in attachment). But I didn't see any leaks with the smoke test. Cleared the codes and SES didn't come back but it usually take a 30+ miles for it to come back on.
Don't have time right now to do a compression test but maybe next weekend, I have to go buy the set at harbor freight.
I'm not touching the o2 sensors because they are reporting normally and I have never had any o2 codes.
And i did log the PIDs (See the attachment I previous posted and they one on this reply, their all logged on one graph with different colors each PID. I've been posting my logs ever since the first post.
I'm not near the car right now but Ill post the vin when I can. I don't know the production date but Ill get the vin.
#27 ·
It sounds like you may have already figured this out, but to be clear, the only time STFT will be out of the normal range is if there is a problem the computer hasn't adapted to yet, or if it is so bad that there isn't enough adaptation available with LTFT. The LTFT is basically a 3D graph that accounts for all possible engine loads and RPMs, so it will account for the exact current fuel demand of engine, as long as nothing has physically changed recently.
To rule out a fuel delivery problem I would graph the fuel trims at wide open throttle. If the car can provide enough fuel to keep it from going even leaner at WOT, then you probably don't have any problem with the fuel system.
Like several people have said it sure sounds like a vacuum leak, except for having a pretty normal MAF reading at idle. I would make sure you're getting enough smoke into the intake plumbing before ruling that out. Check for smoke from the dipstick tube as well.
First thing I would do because its so easy, even though its a long shot, is take a look at the air filter. I've seen a really bad one of those give most of the symptoms of a vacuum leak. I suppose it was because it was disrupting the air flow through the MAF.
#32 ·
Heres is my most recent graph with WOT up in the 3k+ RPM range, the LTFT go down to 0% and the STFT go to 25% (Look at attachment). So i think I might have fuel delivery problem. I haven"t done another smoke test yet but that will be for tomorrow.
#34 ·
Hmm, yeah I'd say that definitely doesnt rule out a fuel problem. It looks to me like it doesnt get a whole lot worse with more throttle, but it defienitely doesnt get better either.
Whatever the conditions were in that last graph, the car seemed to like them, at least while the engine was at around idle speed. With the long term around +30 and the short term around -20 that almost gets you in the "normal" range of around + or - 10.
After seeing these graphs I'll be surprised if the car has any significant vacuum leaks unless its in conjunction with more significant problems. It looks to me like it gets worse the more throttle it gets, backwards of what you'd expect from a vacuum leak.
#36 ·
Gents,
chasing a similar issue ...
What should my STFT and LTFT be if things are tight and working correctly ?
I have eliminated the vac leaks and now i am going to use a known good MAF to test to see if things are buttoned up ?
Are there "expected values" at COLD, WARM, HOT, DRIVING?
If they are specified someplace please point me there as I am all for being self sufficient (obviously not in this case).
thanks in advance
#37 · (Edited)
Might be best if you start your own thread to avoid confusion with OP***8217;s issues.
Fuel trims should be as close to 0% as possible. If LTFTs go below -10% or above +10% for a while, trouble codes are triggered.
STFTs are instantaneous and move around a lot. LTFTs are averaged over time and more indicative of the overall fuel management condition.
Suggest you read up on them. Here***8217;s one explanation.
https://www.obd-codes.com/faq/fuel-trims.php
#38 · (Edited)
It was a failing MAF. I also replaced the exhaust and intake camshaft sensors for good measure. The MAF caused the lean code which cause a dumping of fuel which then cause a fuel tank vent valve code and subsequently my high LTFT and Intermittent stalling. Everything is perfect now. No codes. Cleared my adapts as well and readings are within range.
#46 ·
I agree. I didn't get the MAF code until probably 2 weeks ago which confirmed my diag. The LTFT was high because it just "learned" to dump fuel to compensate for the "unmetered air" (oil residue) on the hot wire. The interesting part was when I got the CAN torque reduction on my recently rebuilt transmission. I had no idea the MAF would tell the ECU to limit torque. I regained a good amount of power and it pulls very nice. I still need to do my front suspension overhaul and coolant system overhaul and she'll be perfect.
