1 - 4 of 4 Posts
need to do a brake job and im ordering parts from AutohausAZ is this a good buy or should i get them from somewhere else?
Getting:
Brembo Brake Rotor; Front Left/Right; Vented 300x22mm - 99.96
Brembo Brake Rotor; Rear Left/Right; Vented 294x19mm- 90.28
Mintex (boge) brake pad set; front OE supplier compound - 42.45
Mintex (boge) brake pad set; rear OE supplier compound Narrow Clip Style - 32.76
Pex/Elca Brake Pad Wear Sensor; Front; 670mm w/ elbow - 9.95
Pex Brake Pad Wear Sensor; Rearl 1410 mm w/ elbow - 8.99
Mahle Fuel Filter; w/ pressure regulator - 47.17
Mann/Mahle/Hengst Oil Filter - 4.72
Hengst (740iL) Oil Filter - 8.55
BMW (OE) windorw regulator front right - 89.98
BMW (OE) windor regulator rear right - 90.00
total - 524.81 w/ free shipping
Discussion Starter #3
well i mean the parts, you know how there are some things that you should get OEM parts because if you dont your car will run funny....
1 - 4 of 4 Posts
