Hi.
I ran a diagnostic on my 2003 E46 N42 318.
The following codes came up:
DME - 2781 - Camshaft Sensor intake
and
DME - 2731 - Vanos Inlet
Vanos intake valve - Possible cause - Vanos adjustment unit for intake- Camshaft leaking or jammed-vanos intake defective or soiled-connector interchanged between intake and exhaust vanos.
I pulled the camshaft sensors and gave them a clean and noticed that the casing is cracked on the lower one. Would this immediately suggest it needs to be replaced?
From what I can tell...the suggestion regarding the vanos is to clean the vanos intake valve. Anyone know anything more?
I just had the timing chain done and the two adjuster units were replaced.
Since getting the chain done, the car has had a strong vibration, not as noticeable at higher speeds but very obvious when pulling off and into 2nd gear. Its a high cycle vibration that makes the car sound like its got an induction kit ! Also vibrating through the dashboard.
Can anyone help me out with suggestions?
and
