1 - 2 of 2 Posts
· Registered
Two problems:
Battery got drained overnight. Not sure why and unit is connected in the way it should (tuner connection to harness). Thoughts?
How do I best route the extension cable from the trunk to the back side rails? On coupes, verts, limos it can be done through the back seat - not possible on foldable touring back seats. Where have you done this?
· Registered
Discussion Starter · #2 ·
Answering my own question as I've found nothing about the touring and it might be of use to others. This is what I found to be a good cable routing, along the passenger side (right hand side) continuing in the same channel as the battery cable uses for routing to the front of the car.
https://imgur.com/a/5cmFk
(couldnt upload images to this site. hopefully imgur doesnt die out)
1 - 2 of 2 Posts
