1 - 19 of 19 Posts
INPA
when clicking e46 the box pops up select e46, chassi, trans, motor, and somthing else. Well under select e46 suppose to be functional test or somthing like that. Mine doesn’t show it so after some googling found to edit the program and now it shows the option. But when I click on functional test it shows these..... no e46
trying to follow the steps of find k-bus issue have the wire pulled off the bar now need to see what module isn’t responding.
this is what I see after selecting functional test
913541
Functional Test is only available for CAS based platforms (roughly 2006 and up). E6x E9x E7x etc
You have to connect to each computer and check errors one by one. Alternatively you could use ISTA.
Sent from my Redmi Note 7 Pro using Tapatalk
You can use INPA but you have to test each computer individually.
He's trying to get in the front door. I'm unfamiliar with ISTA, I use factory INPA.
If someone can get him inside past the door he'll be good.
Discussion Starter #10
I know how to acces info on the car but I’m being told can’t use INPA then I’m being told I can use INPA. Not asking someone to hold my hand but if I’m being told yes and no then what one is it.
Discussion Starter #11
Pretty sure I found it but had no response from any of them. Found out my battery is dead. Looks like I need to do a draw test too. Can hear somthing clicking in the car.
charging it up and will continue tommorow.
Discussion Starter #12
So thought dead battery was my issue for getting this error but Apperently not. Any idea why I can’t communicate?
im choosing from this list
913613
913614
Premium Member
Are you currently having k-bus problems? If you are them you will not be able to see any of the control modules that communicate over the k-bus. You will long be able to see the engine computer and cluster.
Or have you already gone through my k-bus troubleshooting instructions and isolated the wire that was causing the k-bus problems and are now to the point where you are trying to figure out where that wire goes.
Discussion Starter #14
Yes I have followed your troubleshooting and removed the troubled some wire. Been trying to find out what module it went to, so I can move on to test wire resistance or perhaps the module itself.
2004 325i automagic
Are you able to connect to the DME with INPA?
Does the k+dcan cable you are using have pins 7 & 8 connected together internally? If cable does not have a switch, you may have to open the housing a check visually, or test for continuity between pins 7 & 8 with a multimeter.
Discussion Starter #16
pretty sure this is my issue I liked it over and didn’t see a switch, so looked through the clear plastic with a light and pins 7&8 aren’t connected. Got a new cable on the way and will continue when it gets here.
Many choose to solder a jumper and/or with a toggle switch between the two pins.
1 - 19 of 19 Posts
