1 - 2 of 2 Posts
OK first problem: after pulling my pasanger seat out to run wires my airbag light came on, did I do something wrong?
Second: My battery was dead this morning after putting the brain of my Alpine IVA-C800 into the trunk, it was under the passanger seat ,that is were the installers put it but then i could not move the power seat so i took it upon my self to move it to the trunk, only thing i forgot to do is ground the video amp and brain to the frame of the cat. would that drain the battery over night? please anyone can help me that would be great..
1) I believe you needed to disconnect the battery before taking out the passenger seat. Now you'll need to have the airbag light reset at the dealership since it registered a fault.
2) You sure you left everything as the installers left it, just physically moved the brain and amp? Maybe you tapped into a constant 12v source, which is why there was a constant drain?
1 - 2 of 2 Posts
