61 - 80 of 122 Posts
Any metal wools or bird nest inside the catchcan? How is the oil consumption since zero oil caught and drained back?
I don't want to hijack this thread more than I have so I'll answer succinctly as possible. No and zero. None of of bimmers burn any oil between changes.
'02 330CI 5MT
Is the check valve installed backwards on your catch can system?
Discussion Starter · #65 ·
maybe it was but it could have only went in one way it threaded into the catch can. I put the first pcv valve I had originally put in and so far so good. With no pcv valve at all I had a horrendous squeak at any rpm.
'02 330CI 5MT
Gotcha. I'm quite new to the e46 but just trying to dig into this and bounce some things off you or the other guru's on this forum. You mentioned you did a engine rebuild 3k miles ago- is there a change there's something going on with the camshaft gasket or ledge? Maybe something not torqued and it builds up pressure or fails at certain engine speeds?
Discussion Starter · #67 ·
I did not ever think about that but I’m almost positive I torqued everything correctly. It just sprayed oil again everywhere so I can only assume now that it isn’t something to do with crankcase pressure. Now the only thing I can think of is oil pressure
Why not wrap some tinfoil over various sections of the engine front R to try and narrow it down. My money is still on VC or VCG. Why do you assume its not crankcase pressure?
Get the dye kit already.
It depends on if CCV is stock or home brew, and working or not. You might have a positive pressure crankcase instead of negative with a working stock CCV. Cover the oil dipstick tube with an empty plastic bag tight, and see if running engine will suck the air out of bag or add more into it.
OP, have you tried the bag over the dipstick tube?
Dye kit ordered for the win. You've got an interesting treat ahead of you. Take off any engine covers in the way and lift it up if needed so you can start the engine and then immediately start crawling around watching for the beginning of a green colored seep.
I have not done the bag for not due to the fact of at idle if I took off the oil fill cap, I had to pry it off almost with how much crankcase vacuum there is.
Did you connect to manifold vacuum or to the distribution piece on top of the manifold?
I'm curious, why do you guys believe that driving around with that much crankcase vacuum is a good thing?
Discussion Starter · #76 ·
M50 manifold converted, no distribution piece, and all engines have cc vacuum at idle and when under accel it should be neutral.
Well good luck then. Your assumptions will affect how you troubleshoot the issue.
Anyone have specs on what the crankcase vacuum in inches of water column pressure should be?
