1 - 7 of 7 Posts
I have a 1999 323i and i was curious on what size of wheel spacer would look the best without rubbing. The wheel is 18/225... help me out
Uhh those wheel specs mean very little. What is the width of the wheel? Offset? You should be posting something like "18x8.5 40mm 225/40/18".
Discussion Starter · #5 ·
Sorry, The rim is 17 inches with a 9.5 inch offset. The tire width measured out to 9 inches. Do you think 5mm in the front and 15mm in the back would look alright? Who is also a good refferal to order from? Thanks!
offset is the distance from the outside of the wheel to where the hub boots up to it
1. lay the wheel/tire face down on a hard surface...
2. lay a straight edge across the upward facing rim/tire
3. measure from floor to the inside of straight edge (that will give you the overall width of the wheel/tire) (example 10 1/4" or 10.25" )
4. divide that by 2 : 10.25/2=(5.125" or 5 1/8")
5. now measure from the straight edge to the mounting face...(example 6.75" or 6 3/4")
6. subtract the 5.125" (10.25"/2) from the 6.75"=1.625"
7. take the 1.625" x 25.4 (25.4mm=1 inch)
hypothetical answer= 41.275mm... that's the offset...
the wheels should have size and offset stamped on them (inner side)
I would go 5 and 12 if all 4 wheels are the same size
1 - 7 of 7 Posts
