1 - 3 of 3 Posts
Im installing a nitrous ZEX kit in a E46 323i '00 and have problems understanding section 6 in the guidelines..
manual: http://www.zex.com/Technical/Instructions/DryNitrousKit/DryNitrousInstructions.pdf
I cant understand where to connect the two pressure hoses comming from the control box to the engine.
here is the particular section in the manual:
Step 6: Install Regulator &
Intake Hoses
Measure & cut to length the two hoses that lead from the Nitrous Management Unit’s regulator and intake hose barbs. The
regulator hose barb from the Nitrous Management Unit gets connected to the
vacuum fitting on the engine’s fuel pressure regulator
with one of the lengths of hose.
The intake hose barb from the Nitrous Management Unit gets connected to an
unused vacuum fitting coming off of the intake manifold plenum
with the other
length of hose.
(its the section highlighted with bold i need help for :) )
I realize this is "plain english" to most of you, but I cant understand where to hook up the system. i can provide pictures of my engine compartment if someone would please point out where to attach the hoses
1 - 3 of 3 Posts
