2001 E46 325CI - 165,000 more or less miles. Never had issues with transmission.
Guys, this past Friday leaving work started my car and the Cog light was on. The car barely moved as I was driving away and suddenly kicked into gear. Turnoff the car and restarted and it was the same. Cleared the code/check engine light - something about the Wheel Speed sensor came up so that went away but the Cog light was still on. Got the car home finally and slowly through the streets and waited till Saturday morning to figure out what was going on. Saturday went into the car and unplugged the battery for an hour then retried and the light was gone so I figured I was in good shape but not really as I put the car into reverse and the car didn’t move. Grrrrrr! No check engine lights nor anything came up as a warning. Not sure what happened nor what’s going on. Any help would be much appreciated. I’ve read so many different scenarios. Never had any issues with the transmission with slipping nor any signs of the gearing going away when driving so im sure it’s not the transmission but you never know.
