I finally had my KW's v.1 installed today and found out that the ring is rubbing against both front inside tires. I was told to try to use spacers to eliminate the problem. Have any of you guys running KW's had this problem? I was so happy till I started to drive it. :banghead: :banghead: :banghead:
