I can't tell if the whole thing is square or not...
One other outside chance I can think of...other than getting belt dressing cleaned off?
When you pull the idler pulley bolt, it's also supporting the top alt bracket. It is possible for the bolt to be through the front of alt, and not the back, thus tilting the alt enough, that you'd attenuate the squeal (sort of the same with wheel bearings). Make sure, with your magic xl50, that that bolt passes through both brackets on the alt.
Listen with hose, don't assume it's from the work you did, it might be from the work you didn't do...AC pulley I think was mentioned...PS pumps have a bearing and a plastic pulley that does crack.
Did you reuse the AC belt or replace that new. Did you make sure you got the right number of ribs on the belt? Did you buy incredibly cheap replacement pulleys? (Sorry, new parts do go bad...crappy new parts just sooner!)
