1 - 5 of 5 Posts
leakage pump control circuit electrical
where is this located?????????? and how do i fix this ... help please
The code P1470 is for your leak detection pump. It is located on the drivers rear just before the rear wheels. Check lines for the evap sytem first than voltage to the pump.
It could be, but check the easy things first, that would be visual check of the hoses and such and and then see if power is getting to the leak detection pump.
Discussion Starter #5
if you can send pictures of the location of the pump, wires, and other problem that can cause this fault code that will be great. im planning to do a DIY on this.
anyways do you know anything about cold starts? here on e46 they ae saying its either the Idle Control or the Venos Unit.
Thanks alot for your help.
1 - 5 of 5 Posts
