1 - 5 of 5 Posts
Just a moment ago when I was driving my car, the oil temperature goes up so rapidly and the gauge hit the red line. I have seen the indicator for the coolant turned on whenever I started the car in the morning. but it went away after I drove 5 mins.
Is the coolant leaking? Any other problems which can cause that? My car is 3 yrs old with tons of milege (80k miles).
Thanks for any advice
Did you install a separate oil temp guage? Standard guage reads
water (coolant) temp and if you hit the red something is wrong. You're probably significantly low on coolant which may be caused by a leak or maybe you just haven't topped it up in a looong time? Let engine cool down then check level per manual and top up as necessary with 50/50 BMW coolant mix then get the car back up to operating temp and check for leaks-hopefully you won't find one. Good luck
Discussion Starter #3
I think I haven't added coolant for a long time as my last service was long time ago
What is the color of the old coolant?
check ur fluid its probably leaking and ur running with no antifrezze at all , try not to drive it or your going to damage ur engine also make sure ur fan turns , u can also have a bad fan motor
BMW coolant is green however do not substitute with just another green antifreeze, get the BMW stuff from the dealer
and cut it 50/50 with triple distilled water for top-ups-better yet have the dealer flush and replace with 100% fresh stuff if you don't feel confident doing it yourself. Could be that fan is dead but then why does he also get low coolant indicator on start-up? It could be both but that would be a very unfortunate coincidence!
1 - 5 of 5 Posts
