Sorry for the delay. I used the drill to try and widen the hole in the bolt, and then used a much larger extractor kit without success. I heated the bolt hold and the surrounding area with a heat gun and got it to about 200 deg f, then I quench the middle using a can of compressed air upside down so that the super cold gas hit the bolt. I twisted the extractor as hard as I dared without fear of it breaking and making my situation worse. NO LUCK,
The hole is bigger though. I guess next step is to get a plumbers torch and use real heat.
Sapote had asked if the bolt moved at all before it broke, and the answer is NO. When I put the socket and breaker bar to the job, the head just sheared right off and the bolt never budged.
